Open Source Project Mgmt Tools
Six (6) best open-source options for project management.
If you’ve got a dozen big projects on the go, juggling the tasks and responsibilities of each is nearly impossible without a good project management (PM) app. And while you could do all the planning in Excel or set up Kanban boards in Obsidian, nothing quite beats a fully featured PM suite. The best project management tools give you all the planning you need while keeping out of your way, so the project is being managed, not a million settings.
While you could use any of the big names, there are a ton of awesome open-source software options for managing your projects, which are free for community use. If your needs grow, you can graduate onto paid licenses with official support teams, but you can get a lot of work done without that. These tools are great for personal use, with all the tracking tools you’d need to run your own projects from start to finish.
At #6: OpenProject is a powerful project management package that’s got a clean, modern interface and the option of self-hosting or using their own cloud services. The benefit here is that you can save some cash for your project’s needs by self-hosting, and as long as you don’t need more than five users, it’ll stay that way forever. Self-hosting also means you’re fully in charge of your data, which is always nice to see.
